View Full Version : Color Laser Hp 4650, Dead Display
KHAN
03-02-2007, 04:58 AM
hi,
Ihave Hp 4650 Color Printer ,the Display Is Completly Dead,no Led Glows And The Lcd Is Also , But When I Turn On The Printer It Takes Its Warmup ,but Display Is Totaly Dead, I Want To Know Before Checking The Power Supplty Pcb ,is There Any Thing Or Some Codes To Turn On The Display?
Wild Bill
03-03-2007, 10:01 AM
hi,
Hello, Here is what is in the service manual RE: Trouble shooting.
Troubleshooting power-on
When you turn on the printer, if it does not make any sound or if the control-panel display is blank,
check the following items:
1 Verify that the printer is plugged into an active electrical outlet that is of the correct voltage.
2 Verify that the on/off switch is in the ON position.
3 Make sure that the rear fan is running, which indicates that the system is operational.
4 Verify that the firmware DIMM (HP Color LaserJet 4600 models) or CompactFlash (HP Color
LaserJet 4610n and 4650 models) and the formatter are seated and operating correctly.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
6 Make sure that the control-panel display is connected.
7 Check the fuses in the power supply.
8 If necessary, replace the power supply.
9 If necessary, replace the DC controller.
262 Chapter 7 Troubleshooting ENWW
I have seen the panel go blank when I forgot to put back a dimm. Try reseating all and the reseat formatter also. Good luck!
KHAN
03-05-2007, 03:55 AM
thanks For Reply,
ok I Will Check These Points , The Machine Truns And The Fan Also Work The Heater Unit Also Heats,
KHAN
03-09-2007, 06:51 AM
i Visit The Customer Office Today , I Checked All The Points That You Mentioned ,all The Fans And The Heater Unit Works When I Trun On The Printer,
but What They Do , They Says It Was Ok But They Refill The Colors Cartridges And The Printer Work Just For Few Hours And Then Happens That . I Am Going To Check The Power Supply Unit ?
