Hi again guys,
I need some hep again with the BH Pro C500. Every print I do, the printer or Fiery (IP 921) seems to be adjusting the print position on the page to top, right. leaving a bigger margin on the left and bottom.
This is even resulting in my images being cut off on the right hand side and top. To try and explain this better, if I had an image exactly A3 and did not tell it to print to fit, it should cut off a bit on all four sides right? It is not cutting off on the right and at the top.
Where about can I change this setting and is it also possible to change the default 7.5 mm "margin" all round to 5 mm? although the margin is not much of a biggie as such.
I hope I explained this right and you can make out.
Kind Regards,
Nate
Kind Regards,
Nate
