View Full Version : ep2010 drum replacement procedure
mrushing
12-12-2009, 05:28 PM
Never worked on this model, can anyone give me the procedure for removing the drum and drum blade
ck1
12-13-2009, 01:33 AM
Hi,
send your email , i will send the manual for you :D
Tom
12-16-2009, 07:03 PM
The actual drum replacement is fairly simple. Just pull out drum carriage, remove front cover (2 screws) & then remove 2 screws from white plastic drum pin holder behind cover. You will have to take cleaning blade off first, but also simple (1 long screw on each side of blade & spring in the middle) Powder new drum & blade & reinstall. Now, as far as doing the adjustment, I'd recommend looking at an intravia. The 2010 isn't as easy as the 2080 due to no touch screen, so you have to know which buttons to push.
