View Full Version : toshiba bd1510
sunny
03-07-2007, 08:09 PM
How do i reset the technician led blinking on display ???
CJ@CTS
03-13-2007, 03:38 AM
Hold 0 and 8 buttons down while turning it on. 7,9, start, clear/stop, interrupt. Hope you replaced the developer. CJ
CJ@CTS
03-13-2007, 03:48 AM
Previous reply was to reset pm counter. If unit is not working, hold down clear/stop and 8 to read the code relating to the problem. Post the code if needed. C7 is fuser problem. Usually lamp or thermistor. There's also a reset for this code but am reluctant to provide it as much more damage can be done if it's done without the problem being corrected first. U a tech? CJ
sunny
03-14-2007, 09:43 PM
Hi CJ
I hold 0 and 8 while turning on
I get ad
I pres 7.9 then grren button start , display shows 066 some later 412
Then I press clear/stop ad back again.
switched off/on but technician/PM sign stays.
pressing clear/stop and 8 at startup no fault code in display.
do you have some more info ?
thanks sunny
dbrownlee
03-14-2007, 09:54 PM
08 while powering on. 79, then green key, then 000, interrupt, 000, interrupt. power off/ on
sunny
03-14-2007, 10:03 PM
Hi,
I tried this but it did not work.
What do you meen by interupt i suggetst it is the yellow button C/^ key.
thanks sunny
CJ@CTS
03-15-2007, 02:05 AM
If it does not have an interrupt button, try substituting with print key. CJ
dbrownlee
03-15-2007, 01:13 PM
Interrupt is the pause button, looks like an = with an arrow pointing to it. Left side of control panel, under the energy save button on my machine.
Boogotshot
07-20-2007, 03:10 AM
0+8 power on 79 enter set to 0 and hit interrupt recycle power on the machine This will reset the PM counter. Then take the 1550 and throw it out the window. This is by far one of the biggest dogs Toshiba ever put out.
