View Full Version : Bizhub 451 P-14 Error
Toefur
12-14-2009, 07:19 PM
Ive tried just about everything...aside from replacing the print heads. Any suggestions before I get manufacturer support?
P-14 means there is a skew problem. My experience is that it mostly deals with the black IU. 1st pull out the black IU and reseat it. But before locking the black IU hold it in place with your hand then lock it. Sometimes it doesn't sit right. The other alternative is if it doesn't work try replacing the black IU.
PS - as a precaution reseat all IU's
Hope this helps!
Toefur
12-14-2009, 10:41 PM
Thanks 8050. I replaced the black I/U already and have reseated all I/U's as well. I looked on Minolta's SSD site for the P14. Nothing there except what you said...replace the I/U.
There is a special firmware from KM for this problem. PRCB is the only part that has to be flashed with this special firmware (GC1-22).
emujo
12-15-2009, 01:13 PM
had this issue a few weeks ago, tried I/U replacement, no help, installed special f/w, no help. Test mode charts showed black leading in one direction, lagging in other direction. Wound up replacing the PH to resolve this. I am assuming the poster ment 451C. EMujo
Albonline
12-15-2009, 07:54 PM
replace print head unit! have seen ph unit cause maney weird nonlogoical problems on this family of mfps.
Toefur
12-15-2009, 09:18 PM
alright...PH it is...just another lovely day being a KM tech...(sigh)
buster68
12-15-2009, 09:40 PM
Don't waste your money and time on replacing the ph units. Follow this procedure step by step and I guarantee you the P-14 will go away, I've done this on atleast 30 machines and have had success with each one.
1. Do "Skew Adjustment Reset" then run "Initialize+Image Stabilization"
2. Turn off copier.
3. Apply firmware GC1-22 for the Printer control. MFP firmware must be at atleast R5.
4 Do "Skew Adjustment Reset" then run "Initialize+Image Stabilization" again.
5. Turn off and on the copier.
6. Run Gradation for all three modes and then run Stabilizer again.
This has been a fix for me 100% of the time with P-14 codes.
For reference look at TAD # TAUS0703835EN08 in the KM Knowledgebase.
Having a ball
12-16-2009, 12:24 PM
this issue could be firmware depending on the firmware you have at the moment also could be transfer belt check with KM before wasting money.
habik
05-02-2013, 04:09 PM
Hi I am having constant issue with C650 (+650) right this moment and would appreciate if anyone can send me a link to the GC1-22 special firmware on the Konica site...
Many Thanks
I looked through 1.5 hrs now and could not find it.
medmouncef
05-05-2013, 09:58 AM
Hi
Me too, I am interested in the first degree. Please provide us the link or send it to us.
Greetings
Many Thanks
medmouncef
05-06-2013, 11:26 PM
Many Thanks
Look here : http://onyxftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileid=16460&productid=952
For my part, I search without result the service manual for KM c451. If ever, you have it or know where I can find it, I don't to thank you not enough.
Greetings
habik
05-08-2013, 09:15 AM
My Fix was shifting C and M laser to value 300 manualy.
Then all the other adjustments stabiliser reset and full gradation adjust.
"Quite a mile away from initial settings but it worked for me."
medmouncef
05-08-2013, 09:35 AM
2. Turn off copier.
Hello
I followed this procedure to the letter but it did not work.
Greetings
medmouncef
05-08-2013, 09:37 AM
Hello
Can you tell me where exactly did you introduce these values? I can not find.
Thank you very much
habik
05-08-2013, 01:41 PM
in service mode...where you do Skew Adjustment
medmouncef
05-08-2013, 11:09 PM
Thanks. I'll test it on my machine.
mdtrinh
05-12-2013, 03:59 PM
Hope this helps!
Thanks!
We have to replace the black IU to solve the problem.
Bad black IU unit also show up same problem in different machine.
habik
05-12-2013, 06:19 PM
Thanks!
Nice one.
I have changed Bk IU and ITB and no difference. Cleaning skew mechanism apparently helps as someone already mentioned here already...I did not need to do that...my fix was new values in Skew.
Thanks for the info on how you have fixed it!
habik
08-30-2013, 03:20 PM
Just Flashed one of our machines with GSR-R6 and we shall see, if the P-14 comes back. I had it on Manual Skew Adjust with figures
C-480
M-480
Y-193
Now with the Firmware I did:
Skew Adjust Reset + Initialize and Image Stabilise
Flashed with GSR-R6
P-14 went away
Magic :) will see for how long :)
Thanks for watching:) Have a nice weekend folks.
medmouncef
09-19-2013, 03:15 PM
C-480
M-480
Y-193
Flashed with GSR-R6
P-14 went away
Hi.
I have searched the internet nut I do not find this new version GSR-R6. Please Can you send it to me.
Thank you very much.
dirtyfingers
09-20-2013, 11:19 AM
The GSR-R6 isn't the magic firmware to look for.
ALL the Gxx-R6 firmware support the P-14 fix (Threshold changed)
On older firmware (J8/R5 etc )
If the skew correction cannot be done ...then the skew control motors go back to home position.
ON R6 firmware the skew control stays at maximum adjustment if outside the range.
from notes
5. When the alert code P-14 is detected after PH and IU are changed, color registration error or skewed image may occur because the skew correction control is not performed.
Erick Nyaks
03-25-2014, 09:59 AM
Many Thanks
Am also looking for the firmware for bizhub c550 to reset the same skew error any help
habik
03-25-2014, 09:45 PM
Have you looked in the archive?
JustManuals
03-25-2014, 11:32 PM
I have this firmware but it isn't free. If you're interested in buying it, email me at paul@justmanuals.com
Synaux
03-26-2014, 12:04 AM
It is listed in the base firmware...not the special firmware section. Hope this helps
Synthohol
05-06-2018, 02:50 PM
that was 4 years ago.
good luck.
