View Full Version : konica 7040 J33
LY3IJ
12-15-2009, 07:17 AM
copy is completly exited but shows that error code
replaced fusing unit- the same
any ideas?:confused:
copierlady
12-15-2009, 06:03 PM
Exit rollers have no drive. Idler shaft/B (p/n 55GA48140) which holds the reversing drive
gear/A (p/n 55GA77340) becomes loose and drops away from the motor gear (p/n 55GA77340).
rbell12
12-15-2009, 06:43 PM
you might want to check the black inversion assembly attached to the top of the door and make sure that isn't broken. also check the operation of the motor that drives the exit gears. rb
tech51
12-16-2009, 07:08 PM
Haven't worked on one for a while but I seem to remember that the exit sensor actuator can stick in the up position causing a phantom jam. When the side door is opened to look for the paper, the actuator drops back into its normal position allowing the code to clear. It used to happen on older machines when the door support frames got a bit bent out of shape.
