View Full Version : Di251 Copier Problem
nsadler
12-18-2009, 08:48 PM
We have a Minolta Di251 copier which seems to be having the same problem on all of our copy jobs. When making copies all of the reproductions come out offset half way across the page. In other words we end up with half a document on the left side of the page and a blank right half. The machine powered down in the middle of a job (by its self) and when it was turned back on the problem started. It happens regaurdless of the feeder tray or paper size.
fixthecopier
12-18-2009, 11:07 PM
There is an adjustment in the tech mode that centers the image on the paper for each tray, but it will only move a few mm. To be that far off sounds like you smoked the MFB or the CCD. If you do not know what they are, you need a tech.
Its rotating the image. Check that your putting the paper on the glass the same way that its in the paper tray.
