ravikumarj
12-28-2009, 12:24 PM
I happened to repalce a new heater Unit in Di 3510.
after replacing getting error code C0521.
In this model there is a small reset swith on the main panel near ON/OFF switch. I ve activated reset procedure the Panel shows pl wait then again the same error code appears.
But... I ve not done the resetting with opening the front cover!!!! as stated above.
Also I ve tried with old heater unit but it appears the same error code, does not reset.
Kindly confirm and help me.
Thanks in advance.
Thanks in advance.
