Samsung 6322 Lock up
  • DrMark504
    • 13
    Customer turns it on and it runs and clicks and never escapes "System Initializing". Been going on for months. Can't be low toner this long.
    Leaves it off for a day, then fine the next. Now its locked up good.
  • ZOOTECH
    Senior member of CRS
    • 3374
    There were no service tips or bulletins for this problem on this model, but I have seen tips about capacitors in the power supply ready to burst that was causing all kinds of symptoms.
    • tseto
      • Jun 2007
      • 60
      This may sound strange. when all else failed, remove power cable, open rear cover, unplug all connecters to the main board, go have a coffee ( 20 min. or longer_) re connect all connecters. the machine should return to working condition. you could also replace the main board and keep that board for service.
      • DrMark504
        • 13
        Likely answer to problem
        A dealership I communicate with said to replace the main board. I have ordered one. They have replaced several boards on machines after set up before shipping to their customers.
        • toshibadale
          • Apr 2007
          • 117
          For some reason, this model has a lot of issues. Open heat error, locks-up, cooling fans bad, and no telling what else. Samsung did come out with a new fuser for this model, and it seems to have helped the open heat error issue.
