View Full Version : Finding a company to re-write serial numbers on circuit boards
technuthardway
12-30-2009, 06:12 PM
I'm trying to find a company that can re-write the serial numbers on the main circuit board of a KM C500. Someone apparently did some "creative swapping" and we now have a main board for some other C500 that I'm told is long gone. I heard there was a company out there that could do this. I'm hoping someone can save me here! Thanks
Albonline
12-30-2009, 08:32 PM
there is a utility that will do what you want but it is strictly controled by konica. they may clear the board for you if you are a certified tech.
300EVIL
12-31-2009, 09:15 PM
Yeah, they'll do it but the service costs about $1000. You can buy another C500 for that.
Stirton.M
12-31-2009, 10:07 PM
Serial number resides on the NVRAM primarily and cannot be reset without sending this back to KM. It is considered an anti-theft feature, amongst other things.
in 25 mode (press and hold "P" key until machine prompts for 4 digit code. Enter 9272 and press start key.
From there, select 25 mode.
And then "Board change mode"
You "might" be able to correct the number there, but I have my doubts.
kmcopier
01-01-2010, 01:12 PM
save your time It can't be done in the field......It's is as Albonline mentiod strictly ONLY for KonicaMinolta repair center... You can send the boards for reset but I think it's cheaper too buy a new one if you need one .....
You can us this board for testing to find out if you have an problem on a C500.to check if it comes from the board.
You only have then thin stripes on your prints,and if you turn off and on the machine you get a C code..
Gr KMCOPIER
