View Full Version : C220 movie data
Gergő
01-05-2010, 09:03 AM
I wanted to use ID&Print function on this model. Unfortunatelly it doesn't work until you made an Initialization (clear all data). After that I had to switch on the HDD and reload Movie Data.
I don't know how can I reload the Movie Data.
I have movie data and I tried to reload same way as the firmware. But it doesn't work.
It will be wonderfull, if sombody can help me.
Thanks Gergő
B0265
01-05-2010, 09:28 AM
It is the same procedure as for the C652:
http://www.copytechnet.com/forums/konica-minolta/28965-c652-movie-software.html
Gergő
01-05-2010, 01:37 PM
Many thanks
I have found it.
Thank you again.
ims
02-06-2011, 04:27 PM
We have the same problem with the movie data, we tried to update the firmware but there is no change. The movie data is a separate file or it is in the firmware package. If it is a separate file where can I download it?
Thanks in advance,
Stirton.M
02-06-2011, 07:24 PM
movie data files are found in the special firmware section of SSD.
The movie data is loaded in tech rep mode, system 2, load data.
