Yes, google it.... BUT...
the Fiery is a seperate PC/box that is attached to the device to control printing on a more advanced/professional level.
it has it's own software and firmware that is seperate from the copier.
You can easily find specifications on almost any copier if you take 1 minutes to search. Just type: "brochure bizhub C350" (or any other copier) in Google and you'll find dozens of links where you can download the brochures. Usually on the last page you'll find full specs.
Here's a link:http://ubsshop.com/pdf/bizhubC350_brochure.pdf
If you read it carefully you'll see that both the standard and the optional print controllers on this machine are locate inside the copier: "embedded". Read the specs and you'll see the differences between the two... Usually ANY print controller is more then "just a card"... It has most of the components of a computer (usually notebook components), even if they are inside the copier (motherboard, processor, RAM, HDD, PCI slots, etc.).
