View Full Version : Bizhub C-203, Controller issues...
Oystercopy
01-08-2010, 10:44 PM
Customer is able to print for hours at a time, then the machine locks up and won't print anything until it's rebooted... strange.
This customer is also having trouble setting up the scanning function, especially scan-to-email. I was there with the IT guy and it seemed to be a little more troublesome than most to get connected.
Any ideas?
OC
Stirton.M
01-08-2010, 11:37 PM
What is the firmware level of the machine?
Be sure to update it with the latest baseline as a minimum.
You could try to initialize the copier and reset it back to factory level and simply start over as well.
kmcopier
01-08-2010, 11:39 PM
Give some more information >copy>ok? PING>ok? Server>? printer offline on server >?
capture data between server and MFP (wireshark)
alexfixes
01-09-2010, 01:07 AM
Any ideas?
OC
please don't update firmware that does not fix this problem and i have tried it many times wo=ithout updating firmware. thank you
many things could go wrong.1) looks like your print job is queued on this machine. delaying printing. 2)sometime if account track setting have been applied, un registeredaccount name or password have been entered.
3)also you memory may not be suficient, you can perform test print and see if it prints quickly.4) it could also be connection issue, not for sure but I would check that too.I usally unplug the network cable check it out and resetpower off/on then try again. let me know if these things help. good luck
alexfixes
01-09-2010, 01:13 AM
please don't update firmware if already updated,that does not fix this problem and i have tried it many times without updating firmware. many things could go wrong.1) looks like your print job is queued on this machine. delaying printing. 2)sometime if account track setting have been applied, un registeredaccount name or password have been entered.
Stirton.M
01-09-2010, 01:46 AM
We update firmware pretty regularly. If not the latest, then usually just pushing the same level at the machine to correct errant behavior. This is standard practice when dealing with problems with machines that were otherwise working fine previously.
Not to mention there is an edict from KM Japan to update ALL firmware on ALL machines to deal with IU enhancement program.
RRodgers
01-09-2010, 04:27 AM
When ya call into Konica tech support the first thing they usually ask you is "did you install the lastest firmware?"
So one of the first things I always do before calling is flash it up. Usually fixes it for me.
laserman06
01-09-2010, 01:28 PM
Firmware is very important. I too have fixed many problems by upgrading/reflashing firmware. Why are some people so afraid of FW? They put out updated FW to correct many issues. So, when it comes to FW, follow Nike's slogan and "Just do it"
alexfixes
01-10-2010, 01:40 AM
ok, I agree. with you not always FW is solution, why you want update when firmware is already up to date and working. you can follow nike's slogan and just do it. good luck
alexfixes
01-10-2010, 01:46 AM
I agree with you. just do it if it needs the firmware . I have seen some techs flash the machine for paper jams which it turn out to be paper feed roller was bad
alexfixes
01-10-2010, 01:48 AM
Oystercopy
01-10-2010, 02:22 AM
Machine has the latest firmware and I did a Factory Default reset before it left the shop two weeks ago. Machine has about 70K by the way....
OC
Stirton.M
01-10-2010, 12:52 PM
Ok, firmware was latest, but did you reflash it as recommended?
Failing that, you will have to do some digging into the machine, which is why flashing is the first general step in troubleshooting errant behavior that wasn't there before and cannot be corrected by simply cycling the power.
If this doesn't resolve the problem, then best guess is that the machine's MFP board is failing, based on your description of the problem, it contains the network interface. Replace the MFBP.
If there are other symptoms, the problem might be the PRCB, though I have my doubts...site unseen I cannot make that call definitively.
pepper38_cnd
01-10-2010, 02:40 PM
By any chance does this machine have a Bio-Metric device? We stopped sell the Bio for that series because it caused network lockups. Also disable sleep mode and see if you still have the problem, we encountered network lockups when bringing the machine out of sleep mode with a print job.
alexfixes
01-10-2010, 11:15 PM
I have installed about over 1000 machines color and B/w and repaired too.
every machine that we installed Bio-metric caused nothing but toruble,some worked and some didn't . we had all kind of conflicts with network and other issues here in Orange County. good luck with Bio-Mertic.
Oystercopy
01-11-2010, 11:03 PM
No biometric device installed.. LUCKILY...:D
alexfixes
01-12-2010, 01:35 AM
I haven't seen any that works yet.
Oystercopy
01-16-2010, 11:39 PM
O.K. well I went out today and did the recommended NIC Reset procedure with firmware, the one that comes with the NVRAM reset package... not only did it not fix the problem, but now the machine won't let me even GET INTO the Utility/Counter setting to Re-Set the IP Address back into the machine. Waited over 15 minutes.. no dice. So, i reflashed the NIC reset one more time and that didn't work either. I was afraid to (and was recommended NOT TO) do the NVRAM reset procedure, but now I think I don't have a choice. Also, just to piss me off further, the stupid thing gave me a C-F023 error code to boot... Now I don't know WHAT to do... I'm probably going to try the NVRAM reset, but that was a last resort.
Stirton.M
01-17-2010, 02:18 AM
Ok, once again. REFLASH THE FIRMWARE!!!! ALL of it, with the latest firmware.
Resetting NVRAM is the absolute last thing you ever want to do on a machine, when everything else possible to do has been done, which you have not done everything else possible. KM Japan is very adamant about this. All internal counters are reset, not to mention that doing so could also render the machine inoperable under certain circumstances. If you want to verify it is NVRAM, swap NVRAM with another machine (don't print or copy anything, just verify function access). If it is shown that the NVRAM is at fault, you need to send it back to KM Japan so they can clone the chip for you. But I doubt the problem is there.
The error code is one that is related to the MFP board. If firmware flashing does not correct the behavior, your problem most likely is with this board, which contains the system EEPROM where firmware is stored. This board just so happens to contain amongst other things, the network port. See attach file 1 and 2.
NVRAM related errors are limited to only C-D3##. See attach files 3-5
Oystercopy
01-17-2010, 03:33 AM
As I stated, resetting the NVRAM is a last resort, but KM offers that as an option, and their tech support, although not wanting me to do this FIRST, offers it as an option. According the bulletin, only certain things in the machine, which are normal Service Mode changes, get reset during an NVRAM flash. Certainly, KM wouldn't offer it if it destroyed the machine. I've reset NVRAM in other machines before without catastrophic results, but maybe there is something about this particular model that I don't know.
I can try to reflash the firmware with the regular update files, but I'm not sure the customer wlll let me do this now. These people are ultra-stressed about downtime.
Thanks for the reply though...
Stirton.M
01-17-2010, 06:38 AM
I am relaxed. But I am also trying to help you resolve a problem and prevent you from creating more problems for you and your customer. Also, since they cannot print to it, what difference does that make?
And according to this TSB, what I have described to you is the corrective action....
Solution ID TAUS0702439EN* Solution Usage 7
Description
F023.
Solution
CAUSE: MFPB failed.
SOLUTION:Perform a Data Clear. Reseat all the connections on PWB-MFPB. Replace MFPB if necessary and flash MFP with most current firmware. If the problem persists, swap NVRAM.
IMPORTANT: All requests for NVRAMs must be approved by the SSD Hotline and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
PARTS :
bizhub C550 - PWB-MFPB (p/n A00J H020 07)
bizhub C451 - PWB-MFPB (p/n A00J H020 07)
bizhub C650 - PWB-MFPB (p/n A00J H021 00)
bizhub C203/C253 - PWB-MFPB (p/n A02E H342 05)
bizhub C353 - PWB-MFPB (p/n A02E H341 05)
Solution ID TAUS0702927EN* Solution Usage 28
Description
Network menu button is missing from Admin Mode.
Solution
CAUSE: Corrupt NVRAM and/or failed PWB-MFP.
SOLUTION: Perform the NVRAM Recovery Procedure (see attachment for instructions).
If NVRAM Recovery Procedure is unsuccessful, replace the PWB-MFP and NVRAM. To receive a replacement NVRAM, please utilize the Online Technical Special Program order form located within MyKonicaMinolta.com:
1. Login to MyKonicaMinolta.com.
2. Select the Service tab.
3. Select Warranty, Repair, Special Programs (menu at left side of screen).
4. Click on Warranty Services Technical/FOC Programs (in center of screen).
5. Select NVRAM/BRU Replacement Program.
IMPORTANT : All requests for NVRAMs must be approved by the SSD Hotline and a problem ticket generated. If a request is received without an established problem ticket number the request will be denied.
PART NUMBERS (PWB-MFP)
bizhub C250/C250P/C252/C252P (p/n 4038 0121 06)
bizhub C203/C253 (p/n A02E H342 05)
bizhub C300 (p/n 9J06-H003-01)
bizhub C352/C352P (p/n 9J06-0101-02)
bizhub C353/C353P (p/n A02E H341 05)
bizhub C351/C450/C450P (p/n 4037013104)
bizhub C451/C550 (p/n A00J H020 07)
bizhub C650 (p/n A00J H021 00)
Though the above describes to clear NVRAM, this method clears the machine's main counts. You cannot recover that information.
Other TSBs also describes problems that can arise with Licensing depending on any options (like i-Options) installed in the machine, or conflicts that can happen. By a downed machine, I am referring only to the time it takes to get a replacement NVRAM from KM Japan or to deal with red tape regarding certain options in the machine that require a code to reset them. Not to mention the hassle that includes for you and the customer. The following TSBs describe this.
TAUS0800843EN
TAUS0801227EN
Firmware flashing takes 10 minutes at the most. Replacing the MFP board perhaps 30 minutes and another 10 to flash the machine. Do this during their lunch hour if it is such a concern.
alexfixes
01-18-2010, 03:58 AM
I just want to say it's really not wort of falshing NVRAM and that may not even work. i have done that and that didn't solve the problem. The only time I had to do NVRAM refresh was when i was missing
network botton in admin section, i flashed the machine and that din't help, i then did NVRAM refresh and that didn't work, SSD reccomended to repalce the PWB-MFP including the NVRAM together and that's costly because the machine is not under warranty so customer is getting another machine. Aslo is not recommended to just swap out the NVRAM usally when repalcing the NVRAM you have to repalce the PWB-MFP.
good luck
alexfixes
01-18-2010, 03:59 AM
Description
F023.
Solution
CAUSE: MFPB failed.
PARTS :
Description
Solution
TAUS0800843EN
TAUS0801227EN
good luck
Gibraltar's Ghost
01-18-2010, 05:27 AM
From what I have seen so far is that you do not know how to resolve problems with konicas. What I have witnessed in this forum is your constant meddling in the advice of others and confusing the end user with absolute rubbish.
I had a similar problem and following what stirton said was almost exactly what I did to fix my problem with network failur on a C353.
And is it really necessary to repeat your poorly written response several times?
Albonline
01-18-2010, 03:40 PM
yes! quite an excelent observation!
alexfixes
01-18-2010, 06:30 PM
also what i have noticed on this forum that your "manages "don't know what's going on when trying to connect simple scan to ftp network. no one could fix my issue with ftp sacn and I solved it my self and i have happy customers now. to me good field technician is one that knows electrical,mechanical engineering, network engineering and knows how to setup network in any envirenments, whether macintosh or pc, thechs get confuse of servers and they don't want to touch anything on the server.what i have seen so far none of konica techs are able to do these tasks,relax dude, I don't know what you talking about. obuivesly you are not technical and you are far from an engineer. konica techs are trained to just follow manuals and has no experience of fixing machines , all they do is changing parts, i worked with them long time and i traineed thses techs myself, they guy working 20 years still can't connect simple network dude.....dude........
alexfixes
01-18-2010, 06:33 PM
Description
F023.
Solution
CAUSE: MFPB failed.
PARTS :
Solution ID
Description
Solution
TAUS0800843EN
TAUS0801227EN
alexfixes
01-18-2010, 06:35 PM
yes! quite an excelent observation!also what i have noticed on this forum that your "manages "don't know what's going on when trying to connect simple scan to ftp network. no one could fix my issue with ftp sacn and I solved it my self and i have happy customers now. to me good field technician is one that knows electrical,mechanical engineering, network engineering and knows how to setup network in any envirenments, whether macintosh or pc, thechs get confuse of servers and they don't want to touch anything on the server.what i have seen so far none of konica techs are able to do these tasks,relax dude, I don't know what you talking about. obuivesly you are not technical and you are far from an engineer. konica techs are trained to just follow manuals and has no experience of fixing machines , all they do is changing parts, i worked with them long time and i traineed thses techs myself, they guy working 20 years still can't connect simple network dude.....dude........
buster68
01-18-2010, 07:02 PM
after you get the other issues taken care of (C-F023, NVRAM), I'm afraid you may still have a network printing issue. I would recommend putting a network switch(if the IT guy allows it) between the copier and the network, and set the NIC on the copier to Auto negotiate. I suspect that the copier is on a Gigabyte network and for some reason, KonicaMinolta MFP's don't jive well with that network speed. I've seen the same problem on several C203, C353 that are on Gigabyte networks.
alexfixes
01-18-2010, 08:27 PM
Thank you for the information. we can not change anything on this netwrk because it is such huge network here. The mfp on this copier is slower than the network. Once everytime they do have issues with transmitting and scanning, jod doesn't complete the job, and i beleive the speed is the issue like you mentioned..... I have to see if placing netwrok performance monitor will help on this case. i will monitor real time performance for routers,swiches,controllers,snmp devices and controller. If you ahve any other recomendation please let me know.
thank you
dana ahmad
02-06-2012, 04:03 AM
i buy new PWB-MFP Board for ineo+203, but i cant't install firmware on new PWB-MFP ineo+203.
there is no problem with the CF,the firmware, SODIM, and NV RAM. I use a CF 128MB and 256MB. when the CF (compact flash) installed in PWB-MFP, the machine does not react to anything .. just out of picture loading hourglass
whats wrong?..
please, help me..
zoool
12-20-2016, 12:01 PM
please check pins in MFPB. 1 pin can be broken od damaged. if machine is dead replace SODIMM or green board in MFP. its cover for fax.
Hansoon
12-21-2016, 05:15 AM
That original post is almost 6.5 years old!
Hans
emujo
12-21-2016, 06:53 PM
whats wrong?..
please, help me..
What's wrong? Other than hijacking a thread that's more than 6 years old....You say there is no problem with the CF card, I would like to know just how you came to that conclusion. If your answer is "it works on my laptop" then that is where the problem is. Emujo
copier addict
12-21-2016, 07:53 PM
Hey emujo, you are ranting at someone who posted four years ago. lol. I'm sure there are newer post to rant at. :cool:
