Error code CO500 in Minolta Dialta 200
  • vonhetcchtel
    • 42
    Hi. I have an error code in Minolta Dialta 200 and it is displaying CO500.
    Please help me correct this error.
  • lordqpa
    • Oct 2008
    • 22
    This is Fixing Error. Low Temperature. Try:
    Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter “3” from the 10-Key Pad when dot appears at the center on the
    left side of the screen while the start-up screen is being displayed.. You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or termistor. Good luck
