I need system for IP-511 Type A e.g. 6.3.0 or higher. On Europe infohub are only upgrades. Hard disk is damaged. DOS starts. Command d:recovery not works. I need information about partitioning hdd and transffering system to disk.
Need system to IP-511 Type A
sys
send me a PM
it's available on infohub!!
Gr Kmcopier -
If you have an IP-511 A that is currently working, then you can remove the HDD from the controller and then clone it.
We use Acronis True Imaging to create and restore images without a problem. Konica Minolta AUS even recommended this a while ago.
Using this method, you can save alot of time.Please don't ask me for firmware or service manuals as refusal often offends.Comment
Solves the problem quickly...far far more quickly than simply trying to push system through a parallel port, or network port for that matter."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
