ftp scan di470
  • alexfixes
    • 68
    ftp scan di470
    scan to ftp on di470 , can't find distination when scan is done. originally scas to ftp was working.company has moved and they have different server. the ip address and config has been done on server 2003 and copier, the distination name is also the same as copier one touch and is entered correctly. need to setup server for ftp. any inforamtion could help. thanks
  • mrwho
    Major Asshole!
    • 4299
    Konica Minolta has this little utility that creates a really simple ftp server on a workstation. Works on XP, never tried it on Vista and 7, though.
    Wanna try it?
    Mascan42
    Ibid
    • alexfixes
      • 68
      ftp utility
      Wanna try it?
      sure............ anything could help specially that utility that configures autmatically.
      • Mikehub280
        we use freeware ftp typesoft-its wayy better than the le-crappe konica minolta ftp software, it has a log therefor you can see where exactly the issue is. google it.
        • Hansoon
          • Sep 2007
          • 3386
          If the problem is depending on the server utility, here's a good one:
          Quick 'n Easy FTP Server Lite
          Works even with Vista and W7
          Hans
          โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
