View Full Version : konica 7085 VIF :confused:
wwandrei
01-18-2010, 08:05 PM
Hello. I wonder if anyone can help me with a PART NUMBER for video interface card from konica 7085 or DI 850 ... i can`t find it anywere and i have some copiers that has this card broken. (the VIF card is the card from the copier that makes connection between copier and print controller IP602-7085; pi8500-di850). Thank you !
Albonline
01-18-2010, 09:31 PM
IP602/7085 VIF board (p/n 13TL-7311).
Stirton.M
01-19-2010, 02:30 AM
Those little cards are a pain in the ass. You look at them crosseyed and the damn things fail. I've lost count of how many I've had to replace over the years.
wwandrei
01-19-2010, 10:09 AM
Thank you for your replay but i don`t know if this is the Part Number. If you try to google it you can`t find anything about it ... and I have one right in front of me and the Part No written on it is: 13TM-901(2) ... a Part No should be the same for same component ... the Serial No is different. So .... ? And yes those cards are so weak ... I already have 3 broken cards and for konica 7075 (ip601) i lost the count too ... :(
Stirton.M
01-19-2010, 11:58 AM
I've looked through the various parts manuals and even through the TSBs....
What I found was the same as what Albonline (http://www.copytechnet.com/forums/members/albonline.html) found
TSB TAUS0702173EN00 (http://onyxweb.mykonicaminolta.com/newKB/KBDocument.aspx?id=TAUS0702173EN00&ptid=)
Products:
IP-602
IP-602M
7085 Options:
None Specified
Details
Subject:
Does the complete VIF kit have to be ordered to get the VIF board?
Description:
Part number for the VIF board.
Solution:
The VIF board can be ordered individually. IP602/7085 VIF board (p/n 13TL-7311).
wwandrei
01-19-2010, 12:43 PM
Ok. Thank you guys. I more little question : di 850 VIF is the same as on 7085? It seems this is the PN. Any suggestions where I can buy this card? Preferable in Europe, and not from konica minolta `cause their price is "untouchable" :)
Stirton.M
01-19-2010, 01:01 PM
more than likely.
I cannot find other reference to this unfortunately.
mrwho
01-19-2010, 01:10 PM
Probably the VIF is the same. BUT you'll probably have to flash the VIF with the Minolta firmware so it will work.
I say this because I once (a long long time ago) had to install a Minolta controller on a Konica machine (well, actually I had to do it twice, once it was a Minolta Controller on a Konica 7165 and later it was a Minolta controller on a Konica 7075) and it only worked after I flashed the Konica machines with the Minolta firmware.
So, and since I'm almost sure the VIF has its own firmware, you'll probably have some flashing to do.
wwandrei
01-19-2010, 03:09 PM
7075 vif is tha same as di 750 vif i`ve made the test ... no fw needed, but i don`t have a di 850 copier to test that too ... but i assume is the same.
