What does it mean P51 on Konica 1216
  • minolta35
    Trusted tech
    • Apr 2005
    • 87
    I've change a gear rear of the machine and when power on displays P51?What does it mean?It can be reset_?
  • dogsbody
    • Jun 2007
    • 289
    P-51 is an open front door
    The front door pushes a rod that actuates a switch in the back of the machine. If you were replacing a gear for around the fuser this is the general area. Have a look when you open the front door, approximatly above the fuser you will see where the front door pushes the rod. It is a straight line to the rear of the machine where you will find the interlock switch.
    It has been a very long time since these machines were current but that should be the area to look.
    Cheers.
    The force will be with you always.
    • minolta35
      Trusted tech
      • Apr 2005
      • 87
      Interlock switch works well.is it resetable code?
      • mrwho
        Major Asshole!
        • 4299
        It should disappear as soon as you close the door. Either the switch is disconnected, malfunctioning or the door isn't activating the switch.
        Mascan42
        Ibid
        • DCPS
          • Mar 2008
          • 116
          This message had very often with the power supply to do. If you are sure that all the other parts are good then you should think about it.
          • minolta35
            Trusted tech
            • Apr 2005
            • 87
            OK I'll check it again.
            • Coptech
              worker drone
              • 460
              Make sure the door under the bypass isn't open.
