View Full Version : di 3510 lines on copy. help....
brent
01-28-2010, 05:56 PM
just noticed this yesterday. copier is a trade in that I did not notice before. lines on copy. I have attatched pics. I swapped drum. no change. changed dv unit. no change. this machine has no print controller so I can't test print and go around the scanner unit. what else could I check? all the gears in the back seem to be ok. I am asking for help guy's.. thanks
brent
brent
01-28-2010, 06:00 PM
just to clarify. the lines are not in the feeding direction. this is a konica minolta test chart copied from the glass in the portrait position.
thanks. also tried to find out if this machine has a test print section. so I can see if the problem is from the ir. or the printer section
thanks
brent
brent
01-28-2010, 07:22 PM
don't think about it too hard gents. I was able to solve the problem. I swapped out the sync clutch and that transport section and that the paper goes through. so problem solved.
thanks
brent
fixthecopier
01-29-2010, 12:55 AM
Your test print will be the f-12 function. It is a sheet with lines on it.
