View Full Version : Konica 7020 - error j-81-0
manuela
02-02-2010, 01:38 PM
Hallo, i have a problem with a konika 7020 copier, tell me there's an error (J-81-0), but there's no paper in the machine, what can i do?
thank you
bye
Kmdurrin
02-02-2010, 03:52 PM
Description
J81-0 at power up.
CAUSE: Dirty or failed PS1 (registration PS).
SOLUTION: To check PS1 for proper operation, perform the following:
1. Power the copier OFF.
2. Access the 47 multimode (power the copier ON, while pressing the 4 and 7 keys) input code 20, *-001-*.
3. Actuate PS1 (registration PS) to see a change of state on the touchscreen.
4. If no change of state occurs clean or replace PS1 (p/n 552085510) as necessary.
5. Power the copier OFF/ON to exit the 25 mode.
Hope this helps
manuela
02-03-2010, 08:36 AM
Thank you so much, but i'm not a really technichan so i don't understand the commad like 25 mode...can you please tell me what i have to do with a simple mode?
thank you
bye
manu
Kmdurrin
02-03-2010, 03:05 PM
In that case... I would recommend that you call a tech. Dont start messing with the machine if you dont know what you're doing, unless you want to risk causing a more serious problem.
manuela
02-03-2010, 03:13 PM
I call the tech, thank foryour help again!
