View Full Version : Konica Minolta 5510, #1 tray won't lift
fixthecopier
02-03-2010, 10:30 PM
The machine knows if the tray is open or closed, I checked for paper jammed in the plug. I also swapped the feed assembly. When shut the tray does not try to lift, it just keeps saying add paper. Any thoughts?
Hi fixthecopier
Damn!! you bring back bad memories , i had the same problem on a b 600 once and the paper (a very small piece) was jammed inside the connector after all the laying down, bending down and swopping feed units i saw this piece of paper .While i was in the down position i reached for my springhook and got that mf out only to realise afterwards the machine was still on needless to say i blew the control board. Sorry for not being able to help but i just needed to get this of my chest.
Regards
Rudi
fixthecopier
02-05-2010, 01:21 AM
I have a gut feeling about that plug, the one on the machine body is clean and I can't feel anything in the tray side but I can't see it. I'll tak a mirror in tomorrow and look.
manuelcorrea
02-05-2010, 06:29 PM
have you tried lift motor? part #4024-2076-01
fixthecopier
02-05-2010, 10:33 PM
Check plug again today, I guess I will try a motor on Monday
brent
02-10-2010, 11:15 PM
the only luck I had was the paper lift motor. not too hard to change out.
brent
