killersilver
02-04-2010, 04:13 PM
I`m stuck here with the flashing operation for the Di650.
I was getting a SC49-01 error and the solution is to flash the ROM according to the Tech Bulletin 3481A (http://onyxftp.mykonicaminolta.com/mfiles/3481a.pdf)
I got the update files directly from Konica Minolta in a file named sysrom3481a.exe which is an executable zip file containing 4 .bin files and 4 .sum files (one for each board image board, printer board, finisher and VIF).
I succesfully flashed the image board, the printer board and the finisher, without any problems, but when i try to flash the VIF it just doesn`t transfer the files with an error: TERM TEST FILE CAN NOT
SEND.
When i go into 36 mode and print the Machine Management list all the rom versions are correct (according to the Bulletin 3481A) but the VIF says: 00-0000.
Do you have any suggestions?
SEND.
