View Full Version : FS-514 on bh C352, code 1183, Tray stuck in the up position.
bubblegoose72
02-04-2010, 06:18 PM
Came from a wholesaler, and I was working the bugs out of the finisher (bad staple alignment, etc.) and realized that I was shorted one of the trays. While running it the thing stopped at the top and when I cycled the power I got the 1183 code. It does not try to raise or lower, and the exit rollers cycle until it codes out.
Thanks for taking a look!
tech51
02-04-2010, 07:45 PM
Remove the vertical rear cover of the tray section, locate the drive motor at the bottom and manually wind the trays down a couple of inches. Replace the cover and switch on, it should reset.
