View Full Version : bizhub 250
big jase
02-05-2010, 09:33 PM
can anyone tell how do i set up fax kit to print the faxs from tray 2 please
brent
02-10-2010, 11:13 PM
just curious why you want the faxes to print onto tray 2. are you using special paper and want to use that drawer only? also if you recieve a legal sheet will it switch trays on you? do you have 2 drawers only on the macine or do you have more optional trays?
brent
KEVIN900
02-11-2010, 05:37 PM
bigjase, just looked up in the FK-503 manual; and it's in Section 11, Soft Switch Settings. Default Mode 37 is 1111 1000. Change mode 37 to 0100 1000. In the default setting the first group of 1111 corresponds to print from tray 1,2,3 and 4. By changing to 0100, you're telling the fax, essentially; 0100; tray 1-no, tray 2-yes, tray 3-no, tray 4-no. Hope this helps.
big jase
02-12-2010, 03:11 PM
Thanks , That worked great:D
