View Full Version : bizhub c652
big jase
02-05-2010, 09:40 PM
i have a c3b02 code on this model , i suspect to ih power unit board, but just what see if anyone knows this fault before ordering up board
Stirton.M
02-06-2010, 07:42 AM
According to the service manual
3470
tech51
02-06-2010, 08:45 PM
Check the 10 amp fuse on the ih board it's probably open circuit. We have had a number of these boards fail recently. You will need to replace it.
mrwho
05-03-2010, 03:59 PM
I'm just around a C552 with this same problem. The fuse on the IHPU was burned, just as you predicted.
My trouble is, I've put a new fuse in there and now whenever I turn on the machine, the customer's surge protector (I'm not sure if this is the correct name, I'm talking about the set of switches at the facility's power box) turns off.
I'm going to try and check if I can experiment on another outlet.
mrwho
05-03-2010, 04:13 PM
Same results on another completely different power outlet. Going to take out IHPU board and check everything.
mrwho
05-03-2010, 05:06 PM
Well, so far it only happens if the 5-pin connector at the top right of the IHPU is connected - so I think I can rule out the PSU, the IHPU and the heating coils.
On the other hand, now I'm completely puzzled, since I don't know what the heck is going on with this machine!
Help!
mrwho
05-03-2010, 05:33 PM
Hold on to that last post - I've tried it now with the 5-pin connector connected and the coils disconnected and the problem also didn't turn up.
It all points now to the coils - I'm going to order them and see what happens.
B0265
05-04-2010, 07:23 AM
We had this problem on a C552, had to replace both the IHPU and the fusing coil.
yousaf
06-06-2011, 06:24 PM
yes i face this problem first check there is a fuse on the board if with the replacement with the fuse then its fine other wise u have to install a new board i do the same i replace the board
bye and good luck
knight
mrwho
06-06-2011, 09:36 PM
Now I notice I never gave any feedback on my situation - we also solved it by replacing both the IHPU and the Coil. We considered trying just the IHPU, but we didn't want to risk burning a new board with the old coil.
JustManuals
Another dolt who doesn't notice the dates.....
Kuwiat?
yousaf
06-06-2011, 09:41 PM
do u know how to reset the administrator password i try 12345678 and 00000000 both r not working may be some body change but i want to know how to reset the admin password. bizhub C652.
thanks
knight
mrwho
06-06-2011, 09:58 PM
thanks
knight
You can do it in tech rep mode.
yousaf
06-07-2011, 08:47 PM
i know i tech mode press stop 0 and C but nothing happend if u konw any thing new plz let me konw
thanks
knight
peter lynn
06-07-2011, 10:15 PM
I changed an I.H. board on one of these this morning ,following a power cut,solved prblem staight away. this is the fourth I H board ive changed in 12 months an never had a failed coil yet, once it was the fuser unit as well. happy copying peter
