View Full Version : trouble copying in bizhub 420
aleksander
02-06-2010, 04:48 AM
If I used small original, lets say in A6 or name card using original glass. And I used paper A4 size in tray 1 or 2. But the copy output placed in the middle of the A4 paper, like this.
3467
Anyone know the solution?
fixthecopier
02-06-2010, 04:40 PM
Did you override the auto paper selection?
aleksander
02-08-2010, 02:06 AM
I tried using autopaper selection and manual selection, but the result is same. Anything else?
No problem with another bizhub 420. I have 2 bizhub 420 with the same problem.
Mr Spock
02-08-2010, 03:52 AM
Did you initialize the non-image area on the glass in service mode?
Is the center application turned on and set as on as a default?
aleksander
02-08-2010, 05:15 AM
Thank you. I'll try your solution. If it still fail, i'll tell you.
aleksander
02-09-2010, 06:03 AM
No center application turned on. Shall I adjust the non-image area on a glass in service mode? what for?
Thank you.
