C353 Image Transfer Belt reset problem
  • fatboyz99
    • 13
    HI,
    c353 machine is not resting the Image Transfer belt. I Have tried with 2 new ones, But the Fuse is blowing inside the transfer belt.
    Where Could be the Problem? now i fear to put the 3rd Belt,because i could find 80 mAH fuse in the market .
    Some one Advise me ........
  • Toefur
    Service Director
    • May 2009
    • 28
    I had the same problem. I had to replace the MCU PWB to get it to work. Also..look at the top right corner of the MCW PWB and make sure that the 2pin connector is pugged in. Its the only 2 pin connector on the board. Sometimes the plug is not connected at the factory.
    • mrwho
      Major Asshole!
      • 4299
      Also, don't throw those new transfer belts away - you can put 100mAH fuses on them and put them on other machines.
      Mascan42
      Ibid
      • mostertbj
        • Jul 2009
        • 5
        I buy my 80 mA fuses from Communica here in SA or from RSI electronics.
