View Full Version : Minolta di 470 code c13fa
Bri Ski
02-08-2010, 08:48 PM
Does anyone know what part is needed here? first code was c13f7, then it warmed up and made some copies, open and closed side door and now it won't reset past this code. I don't have the manual for this and closest I could use was the di 450. Thanks for any help Brian
lordqpa
02-09-2010, 06:01 AM
Generaly PH Unit (laser) malfunction:
C13F4 Optical System out of adjustment range
C13F5 LD1 intensity adjustment failure
C13F6 LD2 intensity adjustment failure
C13F7 Sub-scanning direction beam position adjustment failure
C13F8 Main scanning direction beam position adjustment failure
C13F4~C13F8 C13FAB C13FC Procedure
1. Reset the malfunction.
2. If the same malfunction persists, change the PH Unit.
3. If the same malfunction is detected again, change the PH Unit.
4. If the malfunction is detected a third time, change Image Processing Board.
Try clean PH Unit.
