View Full Version : km bizhub c351 box utility question
brent
02-09-2010, 12:19 AM
I am getting ready to install a bizhub c351 into an office. and I don't have the original printer drivers cd.
so can I use the konica minolta pcl5c printer driver which includes the box utility? I am pretty sure that I need to use 351 drivers. but will the box utility work the same for both the c350 and c351?
I really appreciate your help.
thanks
brent
Stirton.M
02-09-2010, 01:07 AM
The C350 and C351 are vastly different machines. The C350 IMHO is a POS!
You can download the driver from here.... Konica Minolta Knowlegebase (http://207.194.48.151/intranet2/browse.php?sess=0&parent=4510&expand=1&order=name&sortname=ASC)
There are two variants...if you have a fiery, use the IC402 driver. If no fiery, use the standard.
You can print to box through the driver, but you do not need a print driver for user boxes. User boxes are primarily used for scanning items into and retrieving via the web interface, along with several other uses related to document management.
The box utility is a program unto itself. It is part of the pagescope suite of programs available for all KM machines.
Konica Minolta Knowlegebase (http://207.194.48.151/intranet2/browse.php?sess=0&parent=1267&expand=1&order=name&sortname=ASCThe)
user manuals can be found here...
Konica Minolta Knowlegebase (http://207.194.48.151/intranet2/browse.php?sess=0&parent=3811&expand=1&order=name&sortname=ASC)
