View Full Version : Cl7000 and heavy/glossy paper
dcat127
02-10-2010, 03:54 PM
Is there any adjustment I can make to keep ink from pealing when printing on 24lb. semi gloss paper? I have already tried adjusting fusing temp which helps, but does not solve the problem. It does print nice if you feed through the bypass tray and call it thick stock. Is there any way to force it to feed slowly when getting paper from regular tray?
mikadonovan
02-10-2010, 07:54 PM
Not that I know of. I have a lot of the 7000,7100, and 7200 printers in the field. On media like that, you must use the bypass/thick paper combination to get acceptable prints. I have tried many combinations of driver settings including advanced color settings to no avail. With these machines the rule of thumb is just experiment with different media and use what settings works the best.
