View Full Version : bizhub 470 lines on the drum
abdul
02-10-2010, 10:41 PM
hello everyone
i was working on minolta bizhub 470 and i noticed line on the drum all over it, i did clean the drum, but they came back after close to 800 copies.
anyone could help.
thank u in advance.
abdul
fixthecopier
02-10-2010, 10:44 PM
sounds like the drum blade needs to be changed How many copies are on it?
abdul
02-10-2010, 10:54 PM
I will change the blade, and keep you updated
thank you.
I noticed the parts for minolta copiers getting very expensive , if you know a place where to get theme
please let me know. (beside katun and densigraphix) sometimes they do not have most rollers.
Downunder
02-16-2010, 10:42 AM
I assume you mean Di470 and not bizhub. If the drum has done more than 250-280,000 you will need to change the drum. This is a Minolta quirk. Changing the blad wont help at this stage. not for long anyway. The black lines wll appear a bit blurry (not crisp) lke line from slit glass
abdul
02-17-2010, 04:28 PM
Re: Di-470
as u said , i had to change the drum and blade to solve the problem.
Thank u very much for your help.
Abdul
