View Full Version : Repeating Image
Dave10
02-16-2010, 11:12 PM
We have a customer with a Bizhub C353 which is repeating images on ledger paper. If I copy a letter original onto ledger paper, the image is repeated starting about seven inches from the lead edge. All four colors are effected, so it's not a single I.U. If I set paper type for thick 1, it doesn't repeat, so I suspected the fuser, but a new fuser didn't fix it. I tried changing transfer settings in both directions, and tried turning fuser temps up and down, with no result. Anyone seen this before?
SmellsHot
02-17-2010, 01:33 AM
Whats the life left on the transfer belt? I just had this happen last week on a C353 as well. It needed a new belt.
Dave10
02-17-2010, 02:14 PM
Belt is pretty new, but that doesn't mean it can't fail. Thanks for the reply. I will try it this morning and follow up.
Stirton.M
02-18-2010, 12:30 AM
The problem is not your belt.
Your first clue would be the fuser, since you admitted to setting to thick 1 and the problem went away.
Are you printing to thick paper? Anything heavier than 24lb should be set to one of the 4 available thick settings (bypass tray) or 3 thick settings on all other trays.
Plain paper = 15 - 24lb
Thick 1 = 24 - 40lb
Thick 2 = 41 - 55lb
Thick 3 = 56 - 68lb
Thick 4 = 69 - 80lb
Keep in mind that the machine should give an abnormal low C-code if the fuser was at fault.
SmellsHot
02-18-2010, 02:32 AM
20 bucks says the belt fixes the issue.............haha
copytechman
02-18-2010, 03:16 AM
I'd be inclined to agree with Stirton.M! 7inches from lead edge till start of offset image? Thats WAY too short a pitch for one of those transfer belts!! I'd be heading for the fuser too!
Regards!
A.
Oh yes, as a side note, I've seen dirty print on a linen bond that felt like 20 odd pound paper but wouldnt run clean unless it was set @ thick 1. (c352 series tho) On plain paper.. clean print... the linen stuff.. not so much!
fishleg
02-18-2010, 07:57 AM
Do single sided copies if your repeated image is on the back side its your fuser otherwise its your belt hope that helps. Make sure right settings are set for the paper tho thick 1 etc first.
Dave10
02-18-2010, 02:05 PM
You won't believe this. I couldn't, but the transfer roller fixed the problem. Not sure why, yet, but if I figure it out, I'll let you know.
Stirton.M
02-18-2010, 03:04 PM
2nd transfer roller?
Dave10
02-18-2010, 03:22 PM
yes
copytechman
02-18-2010, 04:25 PM
Wow, good to know!..
SmellsHot
02-18-2010, 06:13 PM
Damn I lost! I'll send the check in the mail! haha
BIG PAPA
02-18-2010, 08:59 PM
Replacing the 2nd transfer roller would change pressue and bias that is being applied to the belt. Was the ghost image from the same page, or could it have been from the previous page? In which case the distance would be in spec for the belt as indiacated earlier. If problem returns.... Replace the belt.
Dave10
02-22-2010, 08:14 PM
The ghost image was from the same page. It's been almost a week and no callback.
copytechman
03-01-2010, 11:56 AM
Heres a twist, i just got a call on friday of last week for a c353 doing what sounds like the exact same issue as the the thread opener here! I'm going in today to have a look-see, and brought both a 2nd xfer roller and a fuser with me, the customer can replicate it faithfully too. So since the second xfer resolved it here, I'll try that first and post the results here. I've seen second transfer do weird things before but nothing quite like fuser type offset images! We shall see. to be continued!
A.
sparkin19
03-01-2010, 06:08 PM
You'd better check the life of the second transfer roller too. The belt and roller do not always get replaced together, purposefully or accidental.
copytechman
03-02-2010, 12:11 AM
K, update as promised. And the verdict: 2nd transfer roller. Same issue, offset image. The 2nd transfer roller fixed 'er up good, and I would never have gone there if it wasn't for seeing the post here! Thanks for the feedback and the fix!
KEVIN900
03-02-2010, 02:23 AM
I will remember this. Great teamwork.
