View Full Version : Toner km 6500 can it be used ?
richvit
02-17-2010, 02:20 PM
Hi on impulse I just bought a load of toner on ebay only trouble is i have not got the copier !! I do have a couple of old minolta cf3102. Is it possible for me to use this toner in these machines many thanks
Stirton.M
02-17-2010, 11:41 PM
No
I agree
An emphatic NO!!!
You cannot use that toner on any machine other than the C6500/6501 series.
anothertech
02-19-2010, 06:32 PM
It's all just crushed bowling balls, right?
mrwho
02-19-2010, 10:53 PM
Wrong.
Both the chemicals inside and the toner diameter matters, even more in modern toner.
If you're feeling like playing russian roulette, go ahead. But more likely than not, you'll come back here wondering why the print quality is so bad that you need to spend some hundred $$$ in order to put everything back right again.
Stirton.M
02-20-2010, 08:31 AM
Wrong.
Also, the C6500 toner is not a crushed product. Every particle is identical in size and shape...spherical.
richvit
02-22-2010, 10:55 AM
Hi thanks for your help I WILL NOT be using in my copier anyone want to buy some toner uk
