View Full Version : Bizhub 360/420/500 Code 6701,6702, C-0000
copyher
02-17-2010, 08:26 PM
Figured I would let everyone know what fixed this problem for us. After replacing the Toner Rotation sensor and removing the Main Board upon booting the machine up we had a code 6701. We re seated the connectors the machine booted up fine, printed fine but would not scan anything properly (garble). We inspected and reseated all morning and it would vary (code 6701,6702, once we had a c-0000). We checked all ICP's including the one ICP3 that is involved in the system. These all checked good. If yours do not then disregard this (OACB). Finally reseating the connectors for about the 6th time allowed the machine to boot up properly knock on wood. Long story short either a bad ribbon cable or bad ribbon cable connections seems to be the culprit. I would make sure you check the CCD and the OACB end of the ribbon cable before turning on.
copyher
02-17-2010, 08:33 PM
Also...I tried reseating the it 5 times before lunch w/ no luck and the 1st time after lunch worked like a charm....may just need lunch ;-)
