View Full Version : Bizhub C-252, won't reset jam code...
Oystercopy
02-18-2010, 01:59 PM
Customer tells me she has to UNPLUG the machine to get rid of the paper jam code. Latest firmware is installed.
Thanks in advance,
OC
Stirton.M
02-18-2010, 03:01 PM
Might be a faulty sensor or sticky flag. Look up the jam event code in history, that will indicate which one to look at.
BIG PAPA
02-18-2010, 09:02 PM
Well first thought is that it is the customer telling you this! Have you seen the problem? If not the customer is probably not opening and closing everything the machine wants, such as the paper trays. No feed jam? Wants tray checked? Just a thought.
agudmove
02-19-2010, 03:29 PM
You need to go to the machine. If it is doing as the customer reports, a good a place as any to begin looking, after the basic resets, is the actuator on the fixer. If its shaft has buckled, there is no free movement of the actuator, it will throw up a jam code and will not reset.
