View Full Version : konica minolta 7155 jam at casset 2
smiley
02-23-2010, 12:58 PM
hi guys i have a problem on this it jams at the exiting the 2nd and 3rd tray i replace the clutch that drives the vertical roller.but nothing improves.any help please.
BIG PAPA
02-23-2010, 07:13 PM
What is the jam code you are getting?
smiley
02-26-2010, 11:25 AM
hello how can i see for the jam code?
jeroen2005
02-26-2010, 04:04 PM
Replace or clean the paper feed regulation gear.This is a one way gear clutch.
BIG PAPA
02-26-2010, 04:09 PM
Try swapping the feed units from trays 1&2. See if the problem follows.
Coptech
02-26-2010, 11:07 PM
25 mode switch 11-7 set to 1 will enable the jam code display.
smiley
02-27-2010, 06:51 AM
hi guys the jam code is 17-02,17-03.the 1st tray and the by pass is workibg tray 2 and 3 doesnt work.thy jam at rigt side cover.
etsmultan
02-27-2010, 12:46 PM
you must check side cover
smiley
02-28-2010, 01:22 AM
yup i check the side cover and try to chit it and find out that the vertical roller is not moving after the paper exited at pick up assembly.
smiley
03-04-2010, 05:39 PM
hi guys i got the sulotion in this problem it the icp5 at the control board.thanks for all you guys.
