View Full Version : again this bizhub 500 now code 2402
salmoz
02-23-2010, 02:33 PM
Sorry but I`m back again with a new problem on this bizhub 500:is now trowing a c-2402 which the counter state as a PCL abnormal connection. I found a worn gear in the toner motor are the two things related or diferent problems?:confused:
BIG PAPA
02-23-2010, 07:21 PM
From the manual.
C-2402 Erase lamp (EL) connector slip-off
abnormality.
When EL turns ON before starting
an initial charging, EL abnormality
has been detected 15 times in
succession at prescribed intervals
after a specified period of time.
Erase lamp (EL)
Printer control board (PRCB
salmoz
02-24-2010, 03:45 AM
Thanks this explain what is the code but please what Ihave to do next?
BIG PAPA
02-24-2010, 01:25 PM
Check your erase lamp connection in the drum unit.
salmoz
02-24-2010, 03:08 PM
Thanks a lot this solved the error code.
