n25an
02-28-2010, 02:28 PM
I had a problem with a kmc3232e this week... the document processor kept saying 8.5 by 14 for 8.5 by 11 and 11 by 17 for 11 by 8.5... I changed the document processor... same issue... I updated the firmware same issue... after doing a few tumbles with tech support... and the systems engineer... my service manager ran across an obscure note about direct light...
the test...
turn off the lights and see if all works...
and/or take an 8.5 by 11 piece of paper and cast a shadow over the sensor
the document processor should start working fine...
if it works...
then the problem is the lighting...
the sensor thats giving the problem is fine... it detects the presence of a particular wavelength of light... the flourescent lighting is giving this off in spades...
the solution...
keep the light off... (works)
move the copier so its not in direct line of sight of the light (works)
make some kind of filter...(might not work)
the test...
if it works...
the solution...
