View Full Version : Print problem with minolta c250
robizhub
03-08-2010, 07:08 AM
HELLO
I Have an intersting print problem:
When a A3plus sheet are almost empty - we have a small image and a few word (black color) - after printing the entire sheet are covered with a gray color like I put 5% or max 7% gray.
But I like the sheet to be white not gray because the gray are not in PDF.
Thanks!
Albonline
03-08-2010, 01:31 PM
you may hve to adjust the 2nd xfer voltage for the papar weight that you are running.
robizhub
03-09-2010, 02:07 AM
so somebody can help me
The gray are present also if the thick of the paper are low (normal paper)
The image I've added is a book cover have to be paper color not that gray.
Albonline
03-09-2010, 01:59 PM
question: does the copier do this when copying also?
robizhub
03-10-2010, 11:16 AM
Thank you for aswer,
Yes are the same problem!
Albonline
03-10-2010, 02:50 PM
try this
robizhub
03-13-2010, 02:17 PM
To Albonline:
Thanks for help!
Gray has disapeared!
Image looks good!
Problem has been solved!
