View Full Version : SR 5000 finsher slows down too much when stapling on the PR01357
rickyd
03-11-2010, 07:04 AM
when doing a stapling job on the PR01357 the machine slows a job down by 30 min to 45 mins per job
TonerMunkeh
03-11-2010, 08:08 AM
Firmware bug? Might be the finisher needs a firmware update to run at Katana speed.
rickyd
03-11-2010, 10:00 AM
I have 2 Pro1107 and 2 Pro 1357 with Sr5000 and I have the same problem when doing a stapling job
on these machines.
they are really slowing down and there is no differnce in speed when stapling the same job on the 1100 and the 1357
I have checked some of these machine have the latest firmware and there is no difference. they are slowing down alot
Rorschach
03-12-2010, 03:44 AM
I'd lean towards a firmware update. I did see that if you're using an interposer, there is a system firmware update to address a loss of print speed.
Also, are you punching these staple jobs? IIRC, the SR5000/PU5000 combination cannot run at 135ppm while punching, and will slow down to ~110ppm... This doesn't explain such a huge jump in job time, though...
