View Full Version : bizhub C220 jam code 11-44
big jase
03-12-2010, 08:49 AM
Has anyone else had this jam code showing on this machine. Causing me a knightmare
I've seen tni report to change wire loom on tray 1 but konica have no stock
Has anyone got a fix
tech51
03-17-2010, 08:52 PM
Had lots of trouble with this code. Main causes are poor quality feed clutches (come with rusty internals from new), deformed feed units which causes binding and slow feeding, and low spring tension on the sensor flag under the large black registration roller. Can be a combination of all these but the clutches are the likely suspects. Set the loop timing to -3 for all trays, this gives maximum loop & seems to help. The wiring fault is not so common but you never know. Hope some of this helps...
big jase
03-17-2010, 09:37 PM
Thanks tech 51 , certainly gives me somethings to try as , KM have no stock on wire looms anyway:D
