View Full Version : dialta351 how can I change IP adress?
javier4065
03-13-2010, 03:11 AM
Hello friends I want to install this copier with RJ45 conector but the configuration page shows 192.168.1.99 ip adress when I change it on the display, I put 10.10.0.155 ip adress,then I press intro.When the copier prints the configuration pages, the ip address doesn't change. How can I change ip address? thanks
Hansoon
03-13-2010, 06:10 AM
Modify the IP adress as you described and than REBOOT machine with the power switch.
Hans
try admin. network setting should be ok...
connecticcut
03-13-2010, 11:48 AM
don't foget to change ip gateway
javier4065
03-13-2010, 12:44 PM
I did all that you above mencionated,the ip address, subnet-mask anf gate away change on the screen,but not on the configuration page.thanks.one friend told me that I can change ip address by internet. how can I do it? Is it corret?
rar0411
03-13-2010, 02:32 PM
connect a laptop directly to the machine and set the laptop ip to the same range, then open a browser window and type the ip showing on the config sheet into the adress bar. this will let you access the web interface of the machine and change settings
mascan42
03-13-2010, 05:11 PM
There are several methods of assigning the IP address on this machine. Check chapter 7 of your NIC operator manual. If you don't have one, here's the link:
http://kmbs.konicaminolta.us/content/products/attachments/manuals/Pi3502Opsnic.pdf
Hansoon
03-13-2010, 07:37 PM
...with a crossover cable ofcourse....
Don't get it, this machine is usually unproblematic. Set the IP-Adress and Subnetmask under Admin>Network and restart machine. That's it. We have had 100+ machines of these series, none of them had this problem. The only thing what can happen is that the NIC starts to fail but this is showing in lost pings, never until now with failing to accept new settings.
Hans
rar0411
03-14-2010, 12:46 AM
any rj45 cable usually works in my experience all you are do-ing is creating a vpn
