View Full Version : Bizhub C203/253/353
bizhub1
03-13-2010, 11:07 PM
Hello, anyone having problems with the sep claw on the transfer belt flipping under and wrecking the belt and if so has anyone been taking them off? Had 2 last week do this and ruined both belts. I noticed the 552/652 don't have the claw so wandering if I can just remove before installing. Thanks
PeterG
03-15-2010, 04:47 AM
Never heard of them flipping under on their own.
But I have seen them put back incorrectly after refusing the belt. Have the belts been refused?
bizhub1
03-16-2010, 01:49 AM
Neither belt has been refused, one machine has 35k on it and the other 80k. This is actually the 3rd one I have seen do this.
aidil rashidi
03-16-2010, 06:25 AM
never heard of the claw flipping on itself but i do face belt ripping due to the paper used by customer that has some kind of glue that cause the claw touching the belt and ripping it.
minimerlin
03-16-2010, 09:40 PM
I have had one unit do this..but I think it was caused by user feeding heavy stock from bypass and it jammed at fuser, folded onto belt/claw. I have not tried removing them but suggest you make sure that the mounting plate is not bent up at all.
tech51
03-17-2010, 09:02 PM
I`ve had a few like this, normally happens after a lot of J30-01 jams, paper tends to hit the transfer belt claw. I would check the jam list to see if there`s an underlying jamming issue. I wouldn`t remove the claw, I saw this done on a C650 once and the result was loads of paper in the transfer belt cleaner.
