c6501 sort and offset prints
  • gamalmehdar
    • Mar 2008
    • 55
    the customer need when send muliple files to print onc . and need the finishing sort and offset by files.
    some filse 1 or 2 bages but some others is more???
    so is this machine support like this functions
    thank you
  • fuckthesystem
    What is the controller in iquestion?
    IC408?
    IC305?
    IC304?
    • gamalmehdar
      • Mar 2008
      • 55
      the print controller s 305
      • TheOwl
        • Nov 2008
        • 1732
        The easiest and quickest thing I can think of would be to have multiple print drivers and each one setup for the specific file. That way the user just selects the correct printer driver when they go to print.
        The other thing is that you can have presets / templates with in the driver which you can save machine settings to. That way, the customer would then have to go into the printer properties and select the correct template which will setup the driver correctly.
