View Full Version : c6500 code on startup
copiers4africa
03-19-2010, 10:50 AM
pls help have any one experinced this problem before...and what was the solution...pls
fuckthesystem
03-19-2010, 11:43 AM
What service code?....in case you are refering to a bizhub Pro C6500!
If not, what engine are you having problems??
copiers4africa
03-23-2010, 06:32 AM
c6708
Techead42
03-23-2010, 10:47 AM
This code is Image Processing related...possible points to T-Shoot below, with potential board replacement:
C-6708* AOC/AGC adjustment abnormality
• Blocking cover and lens
cover of scanner section are
out of place.
• CCD board (CCDB) connector
is disconnected.
• CCDB power cable is disconnected.
• CCDB IC protector is broken.
• Quantity of light of exposure
lamp (L1) is excess.
• L1 does not light up.
Image processing board
(IPB)
I/F board (IFB)
Image memory control board
(IMCB)
Overall control board (OACB)
Scanner drive board (SCDB)
Printer control board (PRCB)
Inverter board/1 (INVB1)
Hope that helps.
jotunn
03-23-2010, 01:41 PM
1. try to update firmware to the latest version, there are the same errors in other Konica Minolta machines (Bizhub 600, Bizhub 601 series and Bizhub Pro 1051, 1200) - worth a try in this case also...
2. check for failed or loose connection between exposure lamp and inverter board
3. check exposure lamp
4. check inverter board
5. check connector on CCD board
boxster964
03-25-2010, 04:09 AM
I just had this code I had to replace the image processing board. I had a lamp that would come on flash for a second then coded C-6708 had level 60 software.
copiers4africa
03-25-2010, 08:57 AM
thank you ..taken your advice and got machine sorted ....
backspace
04-02-2010, 08:23 AM
I had this problem, I replaced the ex.lamp and solve the problem.
drodas78
05-03-2011, 07:20 PM
Hi, what have you done to fix it? I have a C5501 with same problem here. Can you provide me with the latest firmware for it?
Regards
