brent
03-24-2010, 07:15 PM
got a bizhub 200 that was in a location then they moved it. when you touch utility then user settling. there fax button does not shop up. it is just not there next to users choise tab.
I have went into the initial mode and done the image data clear. but now do I have to start over and do a total clear? I am sure the firmware is not up to date. but the machine does fax and copy and print. having a hard time scan to e mail. just need to get into that fax menu.
any advice you copier guru's? fix the copier???? thanks
brent
brent
