View Full Version : Aficio AF2027 printing problem
jackiecck
03-26-2010, 08:33 AM
I print from MS Office 2007 using AF2027 pcl6 driver, selected document & print size to A4, tray 4 but the machine always insist to print from tray 1. I have tried to reinstall the driver & use RPCS driver as well but the same problem still occur. Could anyone help me on this?
Eric1968
03-26-2010, 07:52 PM
Check the document properties of your document, and set the tray settings to automatic. I think the settings are set to tray 1.
cobiray
03-26-2010, 08:16 PM
You can change the default printer tray settings on the machine in User Tools->System Settings->Paper Tray tab.
jackiecck
03-30-2010, 02:29 AM
Paper tray setting was default to 'Auto Tray Select' at driver properties, machine usertools & the word option has set to 'Use printer setting'. The file has 3 pages; 1st & 2nd page will comes from tray1, only 3rd page will comes from tray 4.
cobiray
03-30-2010, 04:44 AM
What happens if you print the file to another machine? What happens if you print the same file from another PC? Did you try the PCL5 driver?
It sounds like maybe the first two pages are not formatted to the same size paper as the last.
jackiecck
03-30-2010, 09:26 AM
i finally found the solution. Thanks for the help.
cobiray
03-30-2010, 11:38 AM
And the answer was.....
jackiecck
04-22-2010, 02:46 AM
It was really the file format difference between the 2 pages and the 3rd page. Just set back the page layout default to auto tray select will do.
