View Full Version : hp 5000n
paul printer
03-30-2010, 12:26 PM
i am an offset printer, i use a hp 5000n printer to make plastic offset plates, they will only work with genuine hp cartridges, in between making offset plates, i print ordinary pages, is it alright to keep changing from generic cartridges to genuine ones frequently.
thank you, paul printer
cobiray
03-30-2010, 12:59 PM
There should be no problem with that outside of the usual issues that crop up from non-OEM cartridges. You will probably see a little toner scattering and the copy quality can sometimes be less than the HP cartridges, but you won't hurt anything by swapping them out.
lonesome
05-24-2010, 09:29 PM
Nothing special really. If you are aware of the dangers of substandard cartridges and non-oem... then you're good.
