View Full Version : problem in the machine BH- 250
abbas saeed
04-01-2010, 09:40 AM
I am a new member with you
I have a problem in the machine BH- 250
Machine re-operation without the work of
The message also appears to me
See picture
http://i265.photobucket.com/albums/ii233/alfajr123/243351.jpg?t=1270110933
Please help
jotunn
04-01-2010, 07:10 PM
PROBABLE CAUSES:
1. Failed fax board interfering with operation of MFBS.
Replace fax board kit, FK-503 (Item #4551613).
2. There is a TCP/IP address conflict between the MFP and another device on the network.
Remove the Ethernet cable from the MFP and PING the TCP/IP address. If the PING succeeds, speak with the Network Administrator and resolve the TCP/IP address conflict.
abbas saeed
04-01-2010, 09:02 PM
I will try to work the steps
brent
04-05-2010, 05:54 PM
before I would order and replace a fax board kit I would initialize the machine. have you tried this>?
brent
abbas saeed
04-06-2010, 11:15 AM
I tried to put a new programming
But to no avail
Someone told me I need to change the Main Board
I do not know what is the solution
The problem did not go
The machine is not connected to NetWork
Does anyone has a solution?
Please
why mean 'I tried to put a new programming' firmware ? did you unset fax kit and try or down the new firmware ? if still problem you must change the MFB board.
tech51
04-06-2010, 06:16 PM
Could either be mfbs board or NVram. I would try parts from a known good machine if possible...
pepper38_cnd
04-06-2010, 11:07 PM
Did you do a Trouble Reset using the warm reset button?
aleksander
04-07-2010, 04:47 AM
It's a bit difficult to solve this problem. First, try to rewrite the firmware. Then check the PWB-A. Then check the PC drum, is it damage on the edge. I've ever face this your problem Abbas Saeed. I check my bizhub 250 and I found the PC drum damage on the right. After replacing the drum, my bizhub 250 running well.
abbas saeed
04-07-2010, 11:19 AM
Thank you all
Finally I know where the problem
The MFB board by the problem
brent
04-07-2010, 02:50 PM
did you have a used mfb board that you swapped out? if you look at replacing that board from minolta with a new bo ard. outchhhh
glad you got it..
brent
abbas saeed
04-07-2010, 04:52 PM
i did not get it , but i removed it from the machine , and i checked it in anther machine with the same modle , the same problem occur
now, i am ordering it from factory.
brent
04-07-2010, 05:24 PM
I just looked up the mfbs board on the konica minolta website. seems they are backordered till may 12th. pn 4551 2038 01 the cost is 1638.36
that is a lot of coin.
can I ask a quick question? what is your marketing area? would a board from the us actually work in a machine from over there? I have always wondered that.
abbas saeed
04-07-2010, 06:24 PM
I work for a company in my country Bahrain
Is authorized by the Konica Minolta in the region for the sale of machinery and spare parts and toner
I got this problem , now the company order to board the request and pay the cost
Known to be expensive
892.865 EUR
