View Full Version : Brother HL-5150D drum unit "salvaging"
After changing the drum and resetting the drum counter, the printer output was "spotty" (because of the fusing unit as I learned later). I tried another new drum (a Brother unit rebuilt by Xerox) and inadvertently :o reset again the drum counter. As far as I know, this process blows a fuse inside the drum.
Is there a way to salvage the second, practically brand new drum unit when the present drum will "wear out"?
Techtime
05-07-2007, 04:41 AM
You can use the other drum unit without a problem. Just go through the same reset process when installing the replacement drum unit. The machine reset a internal counter in the machine itself.
Thank you Techtime, I'm looking forward using your hint in due time.
Aimeelin
05-13-2015, 03:17 AM
Maybe the problem is the drivers, so you can reinstall the drivers for this software, and you can get it from here: Brother HL-5150D Printer Drivers Download (https://www.driverdr.com/brother-drivers/brother-hl-5150d-printer-drivers-free-download).
